tigerwillow1
- Sep 20, 2021
- 194
Win 7What operating system are you using with the Waveshare?
Which inverter are you using? I think I would prefer then to avoid getting the same model....Also very trick is to use only 15S ( 15 cell instead of 16) but it works.
The reason my inverter does not like the 51.2V at startup...
I am having problems getting data from DALY BMS. I am connecting the rs485 A and b ground terminal it is connecting the software but I'm not able read the few parameters.
and also need know the data which is coming the b
A full charge and discharge will automatically set the ah, but might be easier to plug in to PC and configure.Question? i just installed the Seplos 200 amp BMS, it connected to the inverter and has cycled at least 4 times. I have yet to connect the BMS to a PC using the battery monitor software. The default setting on the LCD display shows my battery capacity at 200 ah, but my actual battery capacity is 400 ah. This is resulting in me not using half of my battery capacity. How do i get the Seplos BMS to display the actual battery capacity of 400 ah.
Thanks Shavermcspud, I suspect it should since the manual hints to that. But it hasn't readjusted. So once i get a chance i will try the PC route. Hopefully it should be simple???.A full charge and discharge will automatically set the ah, but might be easier to plug in to PC and configure.
Thanks Shavermcspud, Finally received my USB to RS485 connector and Connected the Seplos BMS to laptop, and I was then able to change my battery capacity from 200 Ah (default) to 400 Ah. Great BMS I should say.A full charge and discharge will automatically set the ah, but might be easier to plug in to PC and configure.
Hi MNRosado is your Seplos BMS able to communicate with the Megarevo Inverter?Thanks Shavermcspud, Finally received my USB to RS485 connector and Connected the Seplos BMS to laptop, and I was then able to change my battery capacity from 200 Ah (default) to 400 Ah. Great BMS I should say.
Hi can my husband contact you please with a very similar communication problem he is experiencing, we are in the UK too. He uses WhatsApp too.The chances are, if you have connected up the adapter and it is a "USB to Ethernet adapter" to the RS485 port on the BMS it will have damaged it permanently, the brown & brown/ white have a 7v+ initial bias + & - on initial connection to determine if a POE switch is connected, this will destroy the BMS's RS485 instantly, hence why you possibly have had no luck on using any of the other adapters if it is indeed an Ethernet adapter?. Although looking at the spec, the white unit appears to be an FTDI USB to RS232 serial port which again is bad news if connected up, RS232 & RS485 are two very different transport layers for communication with different voltages etc. Their website doesn't make it clear what BMS uses what interface, although every unit I have bought and requested an RS485 adapter with has come with the blue USB unit. I'm going to go out on a limb here and say the unit is damaged now. I presume you are in the UK like me? Drop me a private message, if you are local to me, we can do some test on kit I have here.
Drop me a private message on here.Hi can my husband contact you please with a very similar communication problem he is experiencing, we are in the UK too. He uses WhatsApp too.
I have sent message to you thank youDrop me a private message on here.
Hi, my Seplos BMS has arrived , should I be able to communicate with BMS on computer without connecting to battery system?Drop me a private message on here.
