//bms version
Do not try to update a bms with CANBUS with a RS485 firmaware, (or the other) you going to brick the bms if you do that. (need to get it back to seplos to recover). First thing first, you should check which bms version you have. CANBUS or RS485 version?
if you have an mpp/voltronic inverter you should order a seplos bms with RS485 interface (not CANBUS interface) ,
!!!!!! Your inverter should be connected to the port label CANBUS, (yes, the label is not updated) , not the RS485A or RS485B ports.
// cabling
Inverter side -- BMS side
4 --- A ---- ---------- 4
5 --- B ----- --------- 5
8 --- GND------------ 3/6
!!!!!!! do not connect any others pins
// setting
#stop the bms
If you have only one Battery your setting should be
1 2 3 4 5 6 7 8
ON OFF OFF OFF OFF OFF OFF OFF
#restart the bms
!!!! be careful switch is numbered from left to right , but in the document it is right to left. !!!!
