I'm adding a third Seplos Mason 280 to my system to enable me to charge with 300A. I'm trying to wrap my head around the best way to connect them in parallel. Would the configuration below allow me to charge with 300A or would it overwork the middle battery or pull too many amps through the Futronic connectors which are only rated for 250A each?
I know the obvious solution would be to connect all three to the same busbar, but It's a couple of metres run to my Lynx distributor, and I already have enough cables/connectors to do the above.
* Fuses/disconnects have been removed for clarity.
Thanks.
Thanks.
