I have given a battery box to someone a few months ago had no problems still start of month it stopped working. When I opened the case the fuse holder was burnt the smell of burnt plastic was shocking. I have replaced the fuse with a new cables fuse/holder the battery is not coming on. I made me start thinking the position of the fuse. It's between the BMS and the cells. Should the fuse not be positioned before the power from inverter hits the BMS. I'm guessing the BMS is dead now so will replace. When I look at the eel kits they place the fuse at the battery terminal before BMS.
