JäseH
Hi All,
I have a Sol-Ark 15k and 3 batteries with Seplos V2 10E. The Seplos packs are configured in parallel with bus bars and are wired to the Sol-Ark using CANbus. I had an issue with one battery misconfigured and limited to 10 amps that caused a voltage imbalance with the other two packs. The main reason I caught it was because the setup was new and I was testing it out with various loads.
Everything works fine now, but I would like to be able to monitor the batteries individually using Solar Assistant. I confirmed this is possible using my Solar Assistant RS485 adapter with the batteries. Is there a way to ditch CANbus completely and use the Seplos RS485 com port with both Sol-Ark AND Solar Assistant? Perhaps some sort of switch or multiplexer? The RS485 port on the Sol-Ark is currently occupied by SA and I know the batteries can't do RS485 and CANbus at the same time. So this would entail switching all coms to RS485 for:
(1) battery -> inverter
(2) battery -> Solar Assistant
(3) inverter -> Solar Assistant
I tried testing this with an ethernet splitter and didn't seem to work, as Solar Assistant was unable to connect to the batteries. Not sure if it was the hardware I used, or if the protocol doesn't support this.
