I am upgrading the Solar setup on the roof of my 28 ft motorhome, this is a 12V system with 420AH LiFePo4. Current installation has 4 100W Grape Solar panels in parallel installed by the previous owner 10 years ago, (I upgraded from the PWM to a Renogy 50 Amp DC-DC charger with MPPT solar in 2022 with the LiFePo4 upgrade). I am going to be utilizing components I have on hand, left over from other projects, etc. primarily this includes some post hurricane salvage LG Neon 305W panels, and a Victron 100/50 MPPT (the LG panels 40V VOC, 10 amp ISC so no more than 2 in series)
My plan is to keep the current 4x100W panels and Renogy DC-DC MPPT, and add 2 of the LG Neon 305W panels for a total of 1010W using the Victron 100/50
The quesiton is should I wire the LG panels in series or parallel?, note due to placement of the existing panels, vents, sky light, etc. the 2 LG panels will be around 15 feet apart and mounted perpandicular to each other in an L shape. I only mention this as it probably increases the chance that one will be shaded. (spec sheet for the LG panels says they have 3 bypass diodes).
thanks for your thoughts
