Hi gland. I would suggest keeping it simple in this situation. Since two strings do not require fuses, and the MPPT charge controller has a built in breaker, the OP could use an MC4 Y cable, or combiner box (personal preference), then run them right into the charge controller once combined.
The reason I push for simplicity is that adding extra connections can add failure points.
