RaymondDay
- Mar 2, 2021
- 18
Hi I got the PowerUrus S12100 LiFeP04 when I seen the video from diysolar on YouTube and got it that same day for $400.
I power a little server with it. Just 12 volts to all things. Got about 10 External USB Western Digital hard drive on it.
It was working good but it was cloudy all day and 7:00 in the morning the power went off battery was down to zero. Just before the Sun came back out.
So I like to back it up with a 12 volt power supply that's plug in to AC.
I was using the PicoUPS-120-ATV for car application but it stop working. I think my server used to much power for it.
That did work super good. Sort of like a opposite battery backup I guess they just don't make them.
So I want it to run on battery mostly but if the battery gets to low switch to the 12 volt power supply. Then switch back when the battery has more power then the 12 volt power supply that's how the PicoUPS worked.
I did order another same $400 LiFeP04 12.8V 100Ah battery should get it soon then maybe can make it past cloudy days.
Thank you.
-Raymond Day
Thank you.
-Raymond Day
