I'm feeling my years tonight lifting PT 2x12x16's & 20's half the day building a deck on the new house. Fired the contractor last year and am finishing the place myself with help. Retired at 53 now 71 my helper is 26 eeek.. The first issue that bothered me was I couldn't drink a schooner/pint full of water right before bed and had to wake up, that was about 4 years ago. Now it's bladder, muscles and bones since middle of '24.I am right there behind you. Still limping after playing pickle ball with the grand kids. Wife is one me to exercise more as I limp around. Becoming a cranky old fart.
I was thinking about ev battery for the same reason as you. I have a friend who had a Leaf that was damaged and I worked out a deal for it. My curiosity with the ev got the best of me though so I fixed it. Now I have another hungry device and the same size house battery as before!thanks for the reply, and your communication explanation style is good. I thought i saw something up the thread that said the EW batt needs a pretty high 100%SOC voltage compared to the eg4 lfp4v2. Will that be adjustable?
i like to think i am pretty good with electrical and mechanical stuff, but i admit i am not up to speed on ( i'll call it ) the internet of things like CAN bus etc. i kind of know what it is, i would like to know more. but for now i need help with dip switches i guess.
On price I asked someone nicely if they would price match to the EW battery and they said no. So The EW batts are close enough to half the cost of the the other guy, it seems worth a try . i just don't know if i should get one or 2.
i think i have pretty much enough panels to expand into at 20 panels. But for now my battery situation is immediately not enough at 10 Kw h
I really wanted to bring a wrecked EV battery online but that seems complicated for now.
Now for the joke. by the way do you know how much battery it takes to charge a electric car? Well the short answer is basically the same size as the car battery. i know it is not totally true but it makes a little sense.
For now i have 3.4Kw of solar deployed on a good day i have seen 12.2kwh harvested . If you come home at night and need to charge the car it can take 50Kwh EASY plus you still gotta run the house while you are charging. So i am not sure if i will ever get to fully off grid or generator . At least not with out a major upgrade in battery capacity. I knew this going in from the start, but i thought i could do a little better than i am doing now on the battery front.
It seems like a no brainer to buy a wrecked EV for $2 or 3K now; and put that 50 to 85K battery on the house. But it is hard enough that here i am thinking about spending yet another $1000 ish to get another pitifully small battery. when i know i need what seems like 5x more capacity at least.
how big are yalls house batteries????
Holy cow. I'm seeing a whole new market, maybe Black market , but a market nonethelessI was thinking about ev battery for the same reason as you. I have a friend who had a Leaf that was damaged and I worked out a deal for it. My curiosity with the ev got the best of me though so I fixed it. Now I have another hungry device and the same size house battery as before!![]()
The logic still stands and i was looking into using the 400v Leaf battery directly into a high voltage mppt controller. Now I need to find another crashed leaf.....
11 out of 12 bars on the health-o-meter ! Dude, I love it! My SOH started at 100% and keep going down.The cheap one is under 50% on the battery, but the body is nicer than mine. (front end damage and rust). Mine has a battery that shows 11 out of 12 bars on the health-o-meter in the dash and will go at least 50 miles whereas the cheap one is stated as 5 bars and 25 miles. Mine happened to be blue also....
Honestly, I am a bit lazy about balancing voltage monitoring this time of year because we have a lot of rain and clouds all winter, and the battery doesn't get full enough for balancing very often. That said, today was very nice and the blue charge line peaked at 13.6kw, but the solar day is kinda short.Back to the EW battery. how do you all get so in depth on the individual cell voltage matching
There is EW software that lets you see all the cells and fiddle with parameters. It is mentioned many times in this thread. It is called ES-UP-V1.22.16 and can be downloaded from EW. You can connect a laptop to your battery with a usb to rs232 or rs485 cable. You could also monitor via bluetooth on your phone. The software is described in the paperwork that comes with your battery. Have fun playing with it!thanks yes that looks like a eg4 monitor. isn't there a monitor just for the battery, i saw something about hooking up a laptop to the battery.
Well i have a battery enroute i guess i will see how it works out? Any hints on hooking it up to the eg4 LifePower4 v2 batteries
i guess not so obvious for me. how can i go about doing this, when i got my Lfp4v2, i charged them on solar for a couple of half days before i loaded them but that was only because i had not set up the load yetObviously matching their voltage in state of charge when you do that.
The EW battery can talk to the eg4 inverter but not at the same time as the eg4 battery. It is one or the other for comms. Also, the EW and eg4 batteries can't talk to each other because the parallel comms are incompatible. You can run them in parallel as far as the 48vdc is concerned though. I have my eg4 18kpv inverter talking to 15 (max possible) EW rack batteries, and the other 2 EW rack batteries and 4 280ah batteries with JK bms's and a 4s string of a LiTime 12v@230ah are all connected in parallel and working just fine. Total is 156kwh.Sorry I am reading a few different threads on the EW battery and if it can talk to the eg4 batteries and inverter, somehow i think i ended up in the middle of this thread and i was reading another. i will try and catch up
I have the 4 JK bms's on solar assistant to see how they are doing. If I want to see cell details, I have a laptop in the garage with software for both bms brands. I just plug into the master of which ever one I want to look at. The LiTime string has no comms whatsoever. In the future, I may run a usb cable from a usb expansion box (one "usb to 485cable" from each of the 3 masters) to my office so I wont have to go out into the garage.thanks i think a lot of the time i just over think stuff. So how do you switch back and forth to see the different batteries? I am curious to see how it will integrate with my eg4 stuff, and how much adding 50% more capacity will help me. I sure hope that 15Kwh will take care my whole load, Even though i am pretty sure I will need closer to 30-50Kwh if i want to have any luck of charging my car. thankfully i am driving a lot less these days.
It seems that it would be helpful to have a inverter with multiple battery strings just like it is helpful to have multiple solar strings
I am wondering the same thing. I have 6 batteries with the hub on closed loop with a inverter. One battery goes into OV Cell alarm and BMS disconnects. The Inverter doesn't care and keeps charging the others.With multiple packs in parallel is using closed loop really worth it?
