Server Rack Eco-Worthy 48v 100ah and EG4 6000xp comms.
For most batteries/BMS, the protocol selection is only for the BMS to Inverter closed loop communications. The battery to battery protocol is fixed and usually proprietary to the BMS manufacturer.
guess I'm gonna wait to grab another EW battery. had it in cart at the right place. didnt have credit card security number on me, then they jacked the price back up...
the perils of solar buying lol
Some of these batteries are proprietary but almost everybody's opened up to all the different protocols The cat's out of the bag.
The ones that are locked down on their proprietary protocol are going to be the ones people going to stop buying.
So I have been reading various threads on the eco-worthy server rack battery and eg4 6000XP and I just have an overall question on the communication. Does it work with the 6000XP in closed communication with just one of the server rack batteries? It seems the issue is when you have multiple batteries in parallel for closed communication? Is this the case?
The master battery CAN bus output acts like one large battery. If you have 4 E-W batteries plugged into the master CAN it will output as one 400ah battery.
It can do numerous protocols by Pylon is the default and most accepted. It is not compatible with EG4 batteries but Inverters yes.
I just got 6 new EW server rack and my 6000xp only charges at 54.7v. But it does get to 100% charged. I cant get it to 56.6V.
For 6000xp in the Monitor setting for Lithium type what are you guys setting it to? Choice is 0 to 21 in the EG4 site on compatibility list it does not show the EW battery
Im connected via Pylon in the EW app.
What's a target first charge of a new battery other than 100%? Im charging each one at a time.
After many cycles and everything balanced perfectly 56.8V is the BMS 100% reset voltage on the EW. I change mine to match the EG4 LP4 V1 with the latest firmware to 56.6V.
The first couple of times charge it and not everything is 'broke in' and balanced you need to get it to 55.2V and above and hold it there for a while. That puts it at 3.45/cell so the BMS passive balancer will start.
Because I am impatient and want to top balance every cell I use my external active balancer on every new battery. This drives Will crazy but it works really good.
Top Balancing welded cell batteries
Thanks for fast reply. Im 100% off grid and need set up quick.
Charging my 2nd battery it did ramp up to 55.7 at 99% Then jumped to 54.7 when it hit 100%
What do you think an actable voltage difference between cells is?
I will for sure get a active balancer like you have. Is there any time frame is good to go back in and do a balance?
Many say don't worry about it but I like them within 50mV or better. Once you get them balanced they will stay balanced as long as you hit the 56.6V mark every now and then and hold it.
You can operate the batteries at a lower voltage where the imbalance doesn't show up and you will be fine. The batteries at 100 present capacity and top balancing are two different things. I don't like for some batteries to alarm out and disconnect and never reach the top knee voltages. That is why I top balance it with an external balancer.
Others will tell you don't worry about it the capacity is there and just use it.
Any clue what Lithium type in the eg4 6000xp
settings?
Maybe Lux power ?
settings?
For the E-W rack batteries I would use the Pylon CAN Buss from the master battery set as No. 1 and all the slaves connect as it says in the manual.
The master will report one really big battery via the CAN.
So select number two for pylon? And I understand the dip switches in Manuel.
Thanks for the help. I got 3 topped of and 3 to go then put all together.
Is there a safer sequence on how to turn on all these with the inverter?
you want all their voltages to be the same (or extremely close)
I prefer to have everything at 100% and let them calm down for a little while then start flipping breakers on. Never had an issue.
Can anyone help me... I have a BESS 48v 200ah battery and I'm not sure what communication it uses with my eg4 6000xp Pylon or Luxpower.
Figured this out this morning. 6000xp will turn off the EPS output if there is zero load after 6-10 seconds. I plugged in a shop light and it stayed on. This is for "portable " power at my shop so there is not a full time load on it. It can be charged up with grid, generator, or PV. It is not as portable as the dolly set ups you see on YouTube but it has way more battery backup. I like more power !View attachment 262797View attachment 262798View attachment 262799View attachment 262801
I really like this setup. I'm gonna attempt with my EG4 6000XP. How do you like the outlet? Would that be able to handle EV charging?
I've had a couple times where the cat has turned off one of my rack mount 5kWhs while it was full. Resulting in low voltage inverter shutoff at 48V with soc showing 33%, with the other two 5kWh batteries drained.
I just turned it back on. No drama, there's a decent current going initially but soon settles down to 30A and below. This was a little after turning the full one back on into the empty bank, no solar charging at the time.
do you have picture of your setup?
