Hoping to get the correct set up. I have watched a lot of Will Prowse’s video (as well as bought the book) and other youtubers but it’s too advance for my solar brain to understand. I have purchased and would like to install a 24v (2 x 12volt in series) 206AH SOK battery with an all in one Growatt 24V SPF 3000TL LVM - 3kW 120Vac on a hand truck dolly. What would I need to connect the two units correctly? Basically, what connection do I need in between starting from connecting the wire from the Growatt down to the battery? I am confused on what amp size, fuse, and breaker are needed if needed.
Is the 4 gauge wire correct? Looking to buy the Windy Nation brand or is there a better recommendation?
Would it better to use the anderson connector? If I went with the anderson connector, what amp do I buy?
Do I need to purchase the PV combiner box? If I do, which one do I need, the 4-1 Solar Panel Combiner Box – 4 circuits to 1 (1 x 63A max output) OR the 4-2 Solar Panel Combiner Box – 4 circuits to 2 (2 to 1)- (2 x 63A max output)?
I would have to get the SOK battery in the same SOC and Will recommended the Progressive Dynamics Battery Charger 12V 45-Amp, since the SOK recommended charge current is 40a, max is 50a. Any other recommendations for battery charger?
Before connecting the battery, I remember Will using something that won’t spark when connecting the battery. What is that called and what is the correct amp size I would need?
What is the minimum solar panels needed?
Sorry if my questions are all over the place. Thank you for reading and advising!
