Thanks a lot for your help, gnubie.
So 50-60Hz is high frequency? In the datasheet you sent it's stated that it can run a 4hp motor?
It's just confusing and most inverters I find are high frequency.
Edit: High and low frequency inverters are basically the same, the only difference is that the low frequency inverters can start up motors with a high surge better?
I found this inverter. Can you please check the SPF 5000T DVM?
The bigger low frequency inverters show a surge rating, while the smaller ones don't.
