Let me preface this by pointing out that I am on a fixed income (SSDI) so expensive components (such as a victron multi-plus) are completely out of the question. I am willing to reasonably replace some components I already have if needed.
The minivan: 2005 Kia Sedona LX (no roof rack so will have to either get one installed or build one)
Components I have already purchased:
2x 100 watt Renogy flexible panels (yes, I know..*smacks forehead*)
Ampere Time 100ah LifePo4 battery (still in box, plan to add a second one)
Epever Tracer 3210an 100/30 SCC
12 volt fuse box
GoWise Power 1000 watt PSW inverter
15 ft MC4 extension cable
2x Two wire daisy chain
80 amp bolt on fuse
Bluetti EB70s 716wh solar generator
30 quart compressor fridge
Genmax GM1200i quiet series gas generator
What I need to power:
The fridge mentioned earlier
Laptop (120 volt, 150 watt input using the brick that came with it)
Phones, led lights etc
At some point I want to add a shore power plug, but it isn't something I have on a priority list or anything.
Currently in Arizona and hope to get used panels from Santan.
Now, I know I need some more components (wire, PV cutoff breaker etc). What I am looking for is advice on which components to add and which I can do without.
12 volt fuse box
80 amp bolt on fuse
