Hi guys,
Another beginner here having trouble setting up the charging profile for my batteries. Batteries are in place, panels are set up (on my van). Turns out I have no idea how to set up the profile and research has only been more confusing.
Here's what I am working with:
Charge Controller: EPEver MPPT 40A Tracer
Charge Controller: EPEver MPPT 30A Tracer
Solar Panels: (3) 160 Watt 12V Renogy Mono Panels wired in series
Solar Panels: (2) 160 Watt 12V Renogy Mono Panels wired in series
Batteries: (2) EWT LiFePO4 12V 200Ah Batteries wired in parallel for 400Ah 12V Total.
Some screenshots of my battery specs. Also attached the battery specsheet:
https://lensdump.com/i/0WZjFx
PCM
https://lensdump.com/i/0WZIIH
I'm not real sure which battery specs I need to be looking at and entering into the controller? The EPEver user manual mentions the Sealed(Default) setting in a table. Right next to it is this: Lithium Battery LiFePO4(4s/12V). Is that the right setting? There is a line in my battery spec sheet under the PCM specs saying Battery Link: 4S. No idea what that means though.
Sorry for the ramble, pretty lost here. Any help would be very appreciated. Thanks guys
PCM
