Settings for Charging Solix F3800 with EG4 Chargeverter GC
dellmed
Atlanta, GA usa
I have 2 x F3800 and got 2x EG4 GC chargeverters. Need proper settings for Max current charging from a Champion 12Kw generator.
I was also planning on trying to see if i can use both Xt60 ports of F3800. I know using the same chargeverter on both ports will stop charge. So use both chargeverters
on both. Any experience please advise
Do you have any updates? I have a 11,500 Champion Generator and one eG4 Chargeverter I bought to charge two Jackery Explorer 2000 Plus Solar Generators with. After the Chargeverter arrived, I realized I would need to install buss bars on the output of the Chargeverter and run DC8020 pigtails from the buss bars to the JE2000+ units. I'll be setting this up this weekend. I havent made progress past this point, so I am curious if you got things set up and working, and what you may have learned along the way. Did you end up needing 2 Chargeverters? If I charge both of my JE2000+ units from a single Chargeverter, do you think something will turn off?
