That's very similar to what I was thinking about doing. As long as it's a bendable straw, I should be good LOLYou could put a Surflo pump in the hole, suspended above the water level. (but those submersibles people linked are probably better protected.)
You could probably put Surflo or any other positive displacement pump above ground, and have a foot valve on the end of the hose. If your water level is < 32' down, you can suck it through a straw.
From there, pump it up hill to a tank for gravity feed. Then you can run the pump PV direct, without batteries.
Not in my case But Thank You for thinking of it!Don't know if these are any good:
2" (50mm) 220V Submersible 0.5HP Bore Water Pump Deep Well Pump Farm Watering | eBay
Find many great new & used options and get the best deals for 2" (50mm) 220V Submersible 0.5HP Bore Water Pump Deep Well Pump Farm Watering at the best online prices at eBay! Free shipping for many products!www.ebay.com
138.0US $ |Water Well Pump 2 Inch Borehole Submersible Pump Mini Deep Well Pump Submersible For Well Submersible Water Pump For Ponds - Pumps - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
I think Grangers used to have a 2" 3-phase monitoring well pump with inverter drive, haven't seen it lately.
One of these submersible turbine pumps ought to be ore efficient than a jet pump.
@austrisv I haven't tested as of yet. We never got to close on the property until 2 weeks ago. I might be waiting until spring nowHave you figured it out, @medic149 ? Maybe even have tested smtg?
I have a shallow well with a pipe too narrow for those submersible/deep well pumps. Last summer was running on inverter and cheap chinese 400W 220V AC above ground. Was doing ok. Would love to switch over to 12V or 24V DC - then would not have any need for AC at all
The 'shurflo's are usually having 8-10ft suction in specs. I would need ~15ft (would feel safe seeing 20ft in spec and going easier). Or am I just looking at wrong suppliers?
