ianganderton
Auckland, NZ
One of the key parts to planning a system is understanding your predicted power needs and doing a power audit. The problem folks have is finding the data they need to do this so I thought it might be worth folks sharing to make it a bit easier
I think it needs to include a good description including model numbers where appropriate. Also not if your data is measured or estimated
Here's some info I've estimated
Item | Voltage | Time (min) | Watts | Energy (Wh) | Notes |
Device Chargers | 12V | 300 | 1 | 5.0 | |
Laptop | 240V | 275 | 45 | 206.3 | |
Hair Dryer | 240V | 10 | 1000 | 166.7 | |
Toaster | 240V | 8 | 1000 | 133.3 | 12 minutes is about 6 slices of toast so I've budgeted for 4 |
Kettle | 240V | 5 | 2000 | 166.7 | 1 minute per mug of water boiled |
Microwave | 240V | 5 | 1000 | 83.3 | 1 corn takes 4 minutes |
Lights | 12V | 240 | 20 | 80.0 | |
water pump | 12V | 20 | 40 | 13.3 | |
Diesel Heater | 12V | 360 | 22 | 132.0 | 10A on start up 2.5 min. Boost 34W, High 22W, Med 12W , Low 8W , Standby 5W |
Fantastic fan | 12V | 150 | 21 | 52.5 | low 1.3A, hi 1.75A (NB-higher for summer, but heater would be lower) |
Fridge 85 liter Bushman | 12V | 863 | 32 | 460.3 | |
TV | 12V | 120 | 36 | 72.0 | |
Fridge 85 litre Engel | 12V or 240V | 863 | 32 | 460.3 | Rating 12V 2.6A (32W) 240V 0.41A (48W). 14kW per month = 460W per day |
