Hello everyone, I have 2 inverter one of them is a pump solar inverter that has 20 panels 545 watt connected to it 3strings 7 panels in each string with a total of 350 volts.
The second inverter is a hybrid utility/battery/solar
That has 2 panels in parallel connected to it.
The main problem I'm facing is that the pump inverter output is 300 rather than 380 so I'm trying to uplift the input voltage of the pump inverter by connecting 11*2 panels in parallel this requires sharing the hybrid inverter panels (2 parallel) with the pump panels. (for summry I want to to connect 11panel in series and the second 11 panels I want to share one of them with a hybrid inverter)
can this be achieved without adding any external devices/switches? Just so you know the watt output of the panels 11x2 is 11990 far exceeds the required pump watts of 5500watts
