Needing to install export limitation to 3 of my Inverters, to start things simple let's just look at the two Solax 6kw X1 Inverters.
They have the option of CT clamp or Chint DSU666 meter on Rs485. The Chint meter is more obtainable so have gone with that option for now, but using a single meter can the rs485 signal cable be connected in Parallel between the two invertors. Solax couldn't say so have tried it but getting fault on one inverter.
With no connection the inverter shows constant meter fault. With Parallel connection one is fine and happy the other shows a meter mault every few seconds and won't start up. If either unit has the signal cable pulled the other is happy.
Am I missing something or should I just bite the bullet and get second meter feeding each unit with its own? With so many systems my meter cupboard is getting full of meters and Ct clamps!
