Looks good, 302Ah on this test.
Did you fully charge the cells? I do see the default crappy leads which came with the supplies, so it might be possible to add some more charge. And from the other side, you can go down to 2.5V, so there might be some more Ah, so I think they will come pretty close to the advertised 310Ah
edit: Didn't read properly, 302Ah and not 306Ah.. There is always some variation between the cells, the EVE's tended to be slightly lower than their rated capacity also, the Lishens were somewhat higher than advertised, but I won't complain since they are 'grey marked' cells.
Wondering about other cells if the testresults of other cells are similar, or if there is a huge difference between the various cells.
My first reaction would be: Nice, still 20-30Ah more than the common 272/280Ah cells, for only a few $$ more.
Are these the ones with welded studs?
(I have some ordered also from Basen)
