Shenzhen Basen vs Shenzen Luyuan Lifepo4?
BobFlyer
I can add I purchased 8 of the 105ah cells (matched grade A) from Amy for approximately $520 (slightly under) including shipping, taxes, and Alibaba fees in April. Well worth the money.
EVE really would rather not sell to us. Amy gets the cells from EVE, but has committed to buy a quantity each month. You will receive the test reports for each cell from EVE.
Message Amy on Alibaba chat and get a quote. You will be very satisfied with the quality, and will not receive bloated used cells, but you pay for it.
Thread 'Introducing the New & Improved Shenzhen Luyuan Technology Co.' https://diysolarforum.com/threads/introducing-the-new-improved-shenzhen-luyuan-technology-co.15880/
Thanks I just received a quote from AMY and will be placing order soon. I will also order the 8 of the 105ah. What BMS have you elected to use with these units? My current thought is to go in series for a 24vdc setup at 105ah. Or could parallel for 210ah at 12vdc. This is to be used as a Emergency solar generator for my Florida location during power outages. No real major current draws, but may need time of service for led lights, fans, and other low draw items for several days plus, as you never know. I have a 5kw generator for major appliances. I live on the Panhandle of Florida.
Again thanks
Just John
Photon Sorcerer
Again thanks
I like the JBD (Overkill) much better than the Daly. If at all possible, 24v is much preferred over 12v due to the wire size.
BobFlyer
Thanks, I just looked at the JBD Ali express offerings, and the Overkill offering. Does the JBD work with Android APK? I looked at the link of the Ali express, unfortunately it was Chinese language. Also downloaded the Overkill JBD/users manual, the link for the android APK in the manual from June of 2021 apparently is not valid.
Any suggestion on the software APK as to perhaps a link.
Again thanks
Horsefly
Photon Sorcerer
Denver, mostly
I have the 8S 100A JBD BMS from both Overkill and the JBD store on Aliexpress. The JBD and the Overkill of the same voltage and current are pretty much identical, except that Overkill provides a bit longer set of balance leads, it has better B- and C- wires, and it appeared to me that Overkill had also done some calibration of the voltage readings. I still had to calibrate both of them to match up with my Fluke 175, but the Overkill was closer.
I think the Android APK file that is on the download page at Overkill is the most up-to-date (version 3.1.1026).
Just John
Photon Sorcerer
Again thanks
As far as I can tell, he does an excellent job keeping up with the latest APK.
Both Overkill and JBD use the same app. Overkill does a much better job of testing each BMS, but over all, JBD is just a much more reliable and consistent BMS than Daly. I own and have tested multiple models of both brands.
Direct link to Aliexpress store run by JBD (I verified this with JBD):
Direct link to Alibaba store run by JBD:
Sorry for hijacking this thread.
Stepandwolf
Can you share what your results from the load tests were? Thanks
I created a forum topic just for that purpose:
Posplayr
For my location AZ 85704, I have an 8/21/2021 order into Amy for 32 LF280K for $126/cell plus shipping $4743 grade A matched cells (additional $140 credit card fees for AMX). They were to ship (to me 50-60 calendar days) last week but EVE apparently had a delayed shipment now expected to arrive this coming Monday. This was Friday morning status.
That is $148.21 per cell or the equivalent of $592.87 for 4.
I got a notification that the 32 cell purchase has shipped (it took about 20 days to actually ship due to a delay from EVE). Amy provided the capacity data as well as pictures that you can find in the attached spreadsheet.
Here is the raw data
The raw unordered 32 cells have the following statistics:
I then did a cell data sort from Min to Max , and paired the cells starting with the lowest and highest to create pairs and then repeated 16 times. the resulting in this final capacity estimate for the now 16 pairs.
The statistics of the 16 MIN-MAX pairs is now
The driver for loss of capacity due to cell mismatch is the lowest capacity cell which in the group of 32 was 0.64% below the average but now after MIN-MAX matching is only 0.03% corresponding to 0.186 Amp-hr! . The factory matching of the original 32 is within 1.878 Amp-hr so this process using 32 cell for 16S resulted in a 10:1 improvement in capacity matching. This might arguably be the best case where factory matching reduces dispersion resulting in a uniform distribution rather than Gaussian. This is the distribution of the 32 cells.
Here is what the MIN-MAX pairing distribution looks like. TWT how stable this pairing remains. Regardless it shows exceptional promise, making concern about cell matching a nonissue for large arrays.
Using the factory capacity data from EVE, this balancing procedure is a piece of cake where I can jump right to step #3 after top balancing Step #1 . This will reduce concerns about charging and discharging with uncompressed cells. With an active balancer, you can even just bring the 16S stack up to a 3.6V equivalent voltage (perhaps even 3.55 of lower) and let the active balancer bring the cells into SOC/Voltage agreement
lolailando
Basen or Luyuan are a moot point now that EVE is selling direct and has $109 LF280K cells this is cheaper than either of them plus you are getting it directly form the manufacturer.
for an extra $1.00 they will get them stud welded for you.
I would not be paying more than $135.00 shipped for the LF280K/cell or $540.00 for a set of them shipped.
Can you provide the contact info to buy direct from EVE? thank you
Yurtdweller
Well, I ordered from Amy at Luyaun. I ordered 16 cells@280ah. They are EVE Lf280k. I also got her to send along 4 jbd bms @4s12v,100amps. Total $2607. That works out to $150 per cell, with shipping, plus the cost of the 4bms. Then I discovered that there is a new domestic supplier operating 45 miles from my home and selling EVE lf280n for exactly the same price, But such is life. I may go get some of those cells once I return home. On the road, atm. From Amy, I received full testing data on Friday, and confirmation that the cells are all packaged and heading to the port. All cells reportedly are testing at a minimum of 288, up to 291, and are ir matched to within 1 milliohm. I bought twice as many cells as I need, and plan to build several 12v packs, and keep the lowest two packs, and sell the highest two packs. If jbd permits parallel connection, I plan to make a 12v560ah pack for myself, with the option of converting to 24v in the future. I travel full time, in a yurt, with a jewelry workshop, and I really do not need an 1120ah beast battery. Battery will need to be loaded and unloaded up to ten times a year. I had hoped to resell my cells/packs locally, but with a local distributor in town, I will definitely need to sell them as packs, and not as cells. Test results in screen cap below. Screenshot_20210917-160602.jpg
nekit
Well, I ordered from Amy at Luyaun. I ordered 16 cells@280ah. They are EVE Lf280k. I also got her to send along 4 jbd bms @4s12v,100amps. Total $2607. That works out to $150 per cell, with shipping, plus the cost of the 4bms. Then I discovered that there is a new domestic supplier operating 45 miles from my home and selling EVE lf280n for exactly the same price, But such is life. I may go get some of those cells once I return home. On the road, atm. From Amy, I received full testing data on Friday, and confirmation that the cells are all packaged and heading to the port. All cells reportedly are testing at a minimum of 288, up to 291, and are ir matched to within 1 milliohm. I bought twice as many cells as I need, and plan to build several 12v packs, and keep the lowest two packs, and sell the highest two packs. If jbd permits parallel connection, I plan to make a 12v560ah pack for myself, with the option of converting to 24v in the future. I travel full time, in a yurt, with a jewelry workshop, and I really do not need an 1120ah beast battery. Battery will need to be loaded and unloaded up to ten times a year. I had hoped to resell my cells/packs locally, but with a local distributor in town, I will definitely need to sell them as packs, and not as cells. Test results in screen cap below. View attachment 65547
Where did you find the domestic supplier? Thanks
Stepandwolf
I have mentioned Basen (and it is in the title) in many posts here and that they have matched EVE LF280 batteries domestically for less than buying from some vendors in China. Another user on here just received 8 cells from the same vendor at my suggestion. He is thrilled with them as I was with mine. Mine arrived in a week, his took a little longer, about 2 weeks. Packed two to a box, perfect cells, and load tested to meet their spreadsheet provided from EVE.
lolailando
Whats the contact info for Basen domestically? thank you
Stepandwolf
You still deal with China. They can sell out of their Shenzhen location or out of the US warehouse. They might have also warehoused elsewhere as well.
Basen
Like with the other vendors, use the chat function which will get you into sales. I worked with Emily and another user here got someone named Violet...doesn't matter who you get. Tell them you are interested in the EVE LF280 batteries in their CA warehouse.
lolailando
Basen
Are you sure is the 5 year old Basen? there are two Basens in Alibaba one is 5 years old and another 9 years old.
Stepandwolf
Don't know anything about the 9yo one. I gave you the correct link.
Yurtdweller
MrM1
I'm Here, But I'm Not All There
N. Central FL
I just tried to reach out to Emily Peng on Good Ol' Ablibaba and after I hit send it went to Alex Chen. I've read not so good things about Mr Chen.
