Your 3 can be in the same "plant" but the data is still separate for each. "It is, what it is", We say.Btw, I set up my first datalogger today on one of my SPF-5000 ES inverters (3 in 3phase). Works perfectly, can access shineserver from all computers and also the app. Was a little pissed when I found out that it does not collect data from all 3 but you need one datalogger per. inverter even if it is configed as 3phase...so I ordered 2 more today.
server.growatt.com or if you are in the US server-us.growatt.com, make an account and define a "plant" or installation.
Pretty simple.
Can you please confirm if ShineTools or ShinePhone because i got the official answer from Growatt that ShineTools is only for offgrid while ShinePhone is for all devices.I have a pair of the 3000 LVM off grid inverters and they work fine with ShineTools. Who did you purchase from...can they offer any help?
I forgot what my problem was but I was not logging onto the correct Growatt server. Growatt helped get it sorted out, but I spoke to my vendor first. He helped communicate with Growatt, as I recall.
I have two of the off grid 3000w units. I log onto Growatt US server and have the dashboard that shows what the Wifi units are reporting. That is about all I know on the matter.Can you please confirm if ShineTools or ShinePhone because i got the official answer from Growatt that ShineTools is only for offgrid while ShinePhone is for all devices.
ok thnx, I believe that you using the ShinePhone app instead of ShineTools (both apps available on the appstore)I have two of the off grid 3000w units. I log onto Growatt US server and have the dashboard that shows what the Wifi units are reporting. That is about all I know on the matter.
I am just using my PC on the Growatt web site, so not familiar with the phone app.ok thnx, I believe that you using the ShinePhone app instead of ShineTools (both apps available on the appstore)
