SveinHa
I'm about to install 18 PERC solar panels, each 450W, but in the "worst case" scenario with open circuit voltage compensated for worst case low temperature, the total voltage exceeds the inverter maximum 500V PV input with about 3.5%. This MAY not be a problem but I need to have tought it thru to be on the safe side. The inverter is EASun ISolar SMW 8K.
I can bypass one panel with a relay but to do it simpler with less wiring and fewer possible fault spots, I came up with the idea to short circuit one panel when needed:
Do the solar panels survive being short circuited over time or is it better to use open circuit?
