MetalChef
- Aug 16, 2020
- 25
Hi everyone-
I just bought a fixer upper truck camper that I plan to upgrade the solar power from it's current 100watts to 1000watts+.
The problem is I think I may have ordered the wrong Inverter/Charger on Amazon.
My set up so far is as follows:
3 - Lithium Deep Cycle 150Ah Group 31 Battery by Ohmmu Energy, the BEST 12V battery for RV, Camper, House/Coach, Marine, Trolling, Solar, Off-Grid, Overland, Sprinter. USA made. Tested to the extremes.
5 - Newpowa 200W Monocrystalline 200 Watt 12V Solar Panel High Efficiency Mono Module RV Marine Boat Off Grid
1 - Renogy Rover 60 Amp 12V/24V/36V/48V MPPT Common Positive Solar Charge Controller Regulator Compatible with Lithium Sealed Gel, Flooded Batteries and Bluetooth Module
As you can see my batteries and solar panels are both 12v.
However I guessed I overlooked that the AIMS 4000watt Pure Sine Inverter Charger is 24v.
Reason I bought such a powerful inverter is because I want to be able to run my truck campers 9200 BTU A/C along with 2 computers, 2 television monitors and charge mobile devices, 4G signal boost and fans.
Also at some point I really want to be able to charge my battery bank with my pickup truck alternator.
My question is given my situation, should I exchange my AIMS 4000 watt 24v inverter/charger for the AIMS 3000 watt 12v inverter/charger, or should I just purchase a converter from 24v to 12v for my RV appliance?
Here is the 24v AIMS inverter I purchased:
AIMS Power PICOGLF40W24V120V 4000 Watt Pure Sine Inverter Charger, 24Vdc to 120Vac Output, Remote Panel Available, Auto Frequency, Terminal Block, Multi Stage Smart Charger, 7 Battery Type Settings
Also if I decide to keep the AIMS 4000 watt 24v inverter charger does that mean I need to purchase another 150ah lithium battery to run 2 pairs of 12v lithium batteries in parallel?
Would using a 24v inverter complicate my wanting to have my 12v lithium battery bank charge of my pickup truck alternator?
I'm just a solar and newbie and even though I watched so many YouTube videos, I can really use a second opinion or some expert advice since I'm not real confident that I know what I'm doing.
Thanks!
Thanks!
