should i take VOC or Vmpp voltage in consideration when calculating the max panel possible for my Inverter?
-Inverter max wattage 6500w PV
-2 Mppt 3250w each
-Mppt Range max 425
-Pv input max 500v
solar panel datasheet attached
can i install 20 panels (450w) on my system considering that the 450w is only the advertising wattage while the real wattage is way less??
-2 Mppt 3250w each
-Mppt Range max 425
-Pv input max 500v
