My generation doesn't care for the word 'Hack' or 'Hacked'...
Denotes someone taking shortcuts or doing things in a generally sloppy manner.
Examples,
"That Guy Is A Hack" or "This is a real hack job, we'll have to start from scratch".
Electrical induction silver soldering.
Completely closes up air spaces, 100% electrical conduction potential of any given connection.
If you can get it into the inductor field, and electrical soldering or silver soldering (much higher temps) won't damage insulation or components, you can get the maximum current carrying potential out of connections.
Full on silver soldering will often tear away base material when the mechanical limits of the joint are reached.
Copper will often fail on large conductors before the silver solder fails.
For big, heavy duty battery lugs on big wire, it makes electrical soldering MUCH faster & easier, the wire/insulation doesn't heat up nearly as quickly since the energy is concentrated in the terminal end and doesn't have nearly as much time to conduct up the wire strands.
Big, Heavy no BS contactors for high amp batteries, both over and under voltage opening of the circuit so LFP batteries stay within charge tolerance.
Doesn't matter if charge controller or BMS fails, redundant system to take the battery out of Bank until the issue is solved.
