So my suspicion is my panel/panels are going out.
I've had the harbour freight 100 watt kit for 3.5 years.
My controller that came with the kit went bad, so I bought a Renogy 40a 12/24v controller.
I am currently using a new 35ah agm harbour freight battery.
The control over the past week has been showing 3.0 - .08 amps coming in with a strong 21v incoming. My floating or resting is 12.7 - 12.9 with full of 13.1, which I have only seen 2 times. This has had me concerned so I've been keeping a close eye on things, and noticed the battery ever so gradually going down. Woke up last night to a lowe/no battery error code on the controller so it has been depleting, just at slow rate. It's as if my panels are barely (IF at all) keeping up.
A lot of times I see .08 -1.0, and at times 2.0, rarely do I see 3.0 thru the controller.
This is where I'm confused. Today was a no clouds, very sunny day. At around 12 noon I decided to break out the meter and check things. I got 21v incoming as always, but my amps at that time were 3.3a. Compared to 5.x that's avg incoming that's about maybe half of what I'm supposed to get.
Even more odd is while the meter said 3.3a steady, the controller was reading 2.0 - 1.8, that's a pretty big differece in amps.
I've checked all my connections, everything is clean.
So I'm confused. Why is the meter saying 3.3a while the controller is saying 2.0 -1.8a? Is that normal to have a difference between the two like that?
Also if the 100watt panels AREgoing bad, is this a symptom of that?
I'm looking around at panels but this has my curiosity up, as well as my learning still.
