Steve_S
Emperor Of Solar
This was suposed to be 24V/200AH (reality 175AH as that is what the cells are) and was sitting Stand Alone with no other LFP and NOT using their kraptasic NoName unkown BMS. I had replaced the Aluminium Bus Bars with 110 Copper Stock, ripped out the CCA wire & installed copper welding cable instead internally AND used a Chargery BMS8T. So the only "original" stuff was the casing (nice stainless steel case too) with LED Voltage Readout and the Cells themselves. I do not recall if they had any issues if Paralleled or setup in Series in regards to their Kraptastic BMS.I've got problems. One battery, the positive lead got hot as I was wiring them in parallel. It's been two hours and three of the batteries are reading 13.2v. The one that was hot is reading 12.8v. positive end still warm/hot. This is the first week I have used these additional two batteries. First two were wired in parallel and doing great for the past four months.
@kernel WHAT ? I bought the XUBA 280AH's after this shenanigan
Don't echo the "ignored" you should be better than that, certainly should know better.
