chrisski
Solar Boondocker
- Aug 14, 2020
- 5,183
I don't know if it would electrocute you through the frame, but from other posters on here, an inverter really ought to be direct wired to the battery. In my case, there's a 2000 watt 12 volt inverter that could run a microwave at 130 amps while its powered up, and probably surge to 200 amps. I really don't want that going through the frame.could the chassis be what is connecting the circuit for the negative wire? The neg from one battery goes to the inverter without passing through anything else. The negative from the other battery screws to the trailer frame. Would the trailer frame electrocute you if this were the case?
The more you look at the RV, the more you realize how quickly they kick the things out of the factory by cutting corners. I picked mine up and there were several little things the factory had not fixed that the dealer fixed before I picked it up, and that is almost always the case. I'm reluctant to dig too deep and "look behind the curtain," because I'm afraid of what I'll find. Right now I go with, "Heavy loads are direct wired, and light loads are frame wired." "I peeled back the curtain" and found the ground to my DC fuse box is six gauge wire straight to the frame, and then another piece of six gauge wire straight to the frame for the battery. The biggest loads on those circuits will be the slide outs. I don't like that, but have no idea if its right. There's probably millions of RVs kicked out the door just like that.
I'm the type of person that likes to read in an official source how many amps you can send through a ground frame versus thick wires, but I don't know what that source is. I thought it would be the NEC which I thought would be available for free download, but the NEC code seems to be available for hundreds of dollars, the same for finding out what a particular UL standard is. Without access to those, I'm just doing what I think is safest based off the electronics technician job I was in 26 years ago and what is said in this forums and others. At times I feel like my source is the infamous, "A friend of a friend of a friend."
