RCinFLA
Solar Wizard
- Jun 21, 2020
- 3,563
A good battery monitor measures both the current verses time and battery voltage.
Only thing the battery voltage is used for is to reset amp-secs counter when battery voltage reaches full charge voltage and secondary check for totally depleted battery voltage drop out.
A shunt is just the low value resistor used to measure battery current. The accuracy of shunt resistance is very important. A shunt can get quite hot at higher current, so its design needs to keep its resistance constant over temperature extremes. A good quality shunt is made of alloyed metals to compensate resistance for temperature. Shunts have small separate voltage sense terminals to avoid the high current terminal connections from impacting voltage read across shunt resistance.
Smart BMS's include shunt resistors and battery monitoring firmware, although the chip shunt resistors are not the best quality. The advantage of BMS battery monitor is it can monitor individual cells' voltage where a separate battery monitor can only monitor total battery voltage.
The voltage measurement across the shunt resistance used to compute current also has its own accuracy. All this accumulates errors in the amp-second tally over time. This is why the 'full' reference needs to be periodically reset with a full battery charge to allow the counter to reset and re-reference the 100% state of charge of battery. This clears out accumulated errors in the amp-secs counter.
