My current system is a Sol-Ark 15k with 36 solar panel (10 year old) with two EG4 battery and it is running great, but the Center Point of Energy, a Houston utility company, disapproved my distributed generation (DG) application because the service disconnect which I am using as described in the subject title.
The argument of the utility company is that it is invisible to the service personnel as follows: "Complainant' s Exceptions state that his proposed disconnect device should be approved, because it has a visible on-off switch. He does not dispute that the actual break is enclosed in a molded plastic case and not visually accessible. Only distributed generation disconnect mechanisms that have a visual break are permitted by the Commission' s rule 16 TAC § 25.212(b)(8) to be connected to a utility's electrical system."
Just wonder if anyone can figure out what the utility company, Center Point of Energy, is saying?
