I just pre-ordered some 24V/200Ah EG4-LL batteries from Signature Solar to replace a flooded lead-acid battery bank. Looking forward to receiving them in another month or so.
I would like to connect these batteries to an old Trace SW4024 Dual Inverter Power Panel (http://www.solarhome.org/browseproducts/Xantrex-SW4024-Dual-Inverter-Power-Panel.HTML) with dual C40 charge controllers hooked up to approximately 2k of panels (1k per controller).
I'm concerned because the C40 is a PWM controller and I've heard rumors that these can damage BMSes and LiFePo batteries. Will the C40 be safe to use with my EG4-LL batteries or do I need to upgrade to a different charge controller to avoid battery/BMS damage?
Thanks in advance for your advice!
