No alerts on BMS. Discharge at 150amps.Did you check the JK BMS app to see if there were any alerts? Also what is the discharge limit you have set for the JK BMS?
So you'd need to hit about 7500W to trip it. Have you measured what the surge of the AC is? Even when you say it is "running" the compressor can be turning on and off.No alerts on BMS. Discharge at 150amps.
I found 2 answers online. One said 2900 surge the other said possibly between 3000 - 4000w.So you'd need to hit about 7500W to trip it. Have you measured what the surge of the AC is? Even when you say it is "running" the compressor can be turning on and off.
The inverters do have the over-load shutdown feature so I wonder why it would Low Buss Voltage error instead of overload error if it were in fact an overload.I found 2 answers online. One said 2900 surge the other said possibly between 3000 - 4000w.
I do have 2 inverters running split so it should handle at least 6500 Watts each.
I'm referring to you hitting the discharge limit of the BMS and it temporarily disconnecting the battery.The inverters do have the over-load shutdown feature so I wonder why it would Low Buss Voltage error instead of overload error if it were in fact an overload.
I don't believe that has ever happened.I'm referring to you hitting the discharge limit of the BMS and it temporarily disconnecting the battery.
Checked the battery history. The highest amps draw was 50.I'm referring to you hitting the discharge limit of the BMS and it temporarily disconnecting the battery.
Info coming from Solar Assistant so it must not be the most accurate software. Check back 7 days and still said highest draw is 55-ish.Surge is typically about 4-6X run, so if you're A/C runs at 2,000W, it's surging to somewhere around 10,000W. One needs to measure it with a meter that has an INRUSH function. The "MAX" function isn't fast enough.
Seems pretty impossible when you state both A/C and microwave were running at the same time. A 1000W microwave burns 1600W.
That's 3600W/51.2V/.9 = 78A assuming absolutely nothing else was running.
You can't use SA for surge measurementInfo coming from Solar Assistant so it must not be the most accurate software. Check back 7 days and still said highest draw is 55-ish.
Thank you. I'll have to get one of these.You can't use SA for surge measurementYou'd need something like https://www.amazon.com/gp/product/B08CX6VHWV/
I can't say for sure, so my guess is speculation. I am guessing it means the internal DC bus is not high enough. (This is different than the battery voltage. ) This kind of error is often unrecoverable. One common cause of this type of error is if the batteries are run open loop and suddenly shut off. The sudden change in current can cause a voltage spike on the internal bus that can damage components.
While there could be issues with the inverter like bad dc bus capacitors, you really can't trust the logs to diagnose these kinds of issues reliably as @sunshine_eggo stated. You need to see your AC output inrush current, and ideally your battery inrush current as loads change.Checked the BMS and it is listed as a max continuous discharge of 200 amp and max of 350 amp. Plus no errors from the BMS that I've seen. Still seems more an inverter malfunction than anything else.
I have two 6500s never a problem, it might be due to the fact they have never had power run through them yet. Someone could easily assume there is a problem and that’s why SS is offering a upgrade program that for a $750 each credit they get out of the warranty.Is it just me, or do these inverters seem to be failing at an alarming rate? I've seen many posts here and elsewhere of failing 6500's. Oh and the Solar Assistant thing is pure BS.
I wouldn’t expect anything more out of SS.Contacted SS about a problem with two of my 6500ex inverters. Got through really fast and had a tech on the line diagnosing my problem. Went through everything, all the testing of the units and within an hour the tech informed my that he knew the issue and we could start the return process. Fantastic, I thought! Finally, good customer service. Well that Fantastic turned into nothing but frustration, delays and excuses.
Sent all the info and photos for the return process to begin and then I hear nothing for days. Called to get an update and the very same tech I spoke to acted like he had no idea or interest in my situation. He now wanted me to do random tests that had nothing to do with the issues we discussed, just to delay my issue as long as possible. A full 2 weeks after I was told that he knew my issue and it NEEDED to be sent in for repairs, I was then informed he would send me to Tech 2 support. Well Tech 2 didn't ask much other than to find reasons that this was my fault and the warranty would not be covered but I could pay for it to be repaired.
I didn't complain because it was obvious it would only delay things further, so I sent 1 unit back for repair. They told me it would cost $150 for the repair PLUS parts if anything needed to be replaced. Ended up costing $150 so I can only assume nothing was actually damaged too badly. Probably a simple fuse replacement.
Repair was fast and I did receive the unit back in a reasonable amount of time. I asked the 2 separate people that I had been emailing about the repair, what exactly was wrong with the unit and could I get pictures of the damages as it was listed that they took pics. 2 weeks later I'm still waiting for a response.
Summary:
Contacted SS and was pleasantly surprised how helpful the Tech 1 person was. Until he wasn't!
2 weeks of delays and excuses later, I still had not actually been helped.
SS blamed me that the units had Error 52's (said they did not "SUGGEST" that I could double-land 2 positives onto 1 breaker). Because it was not "suggested" by them, then the warranty would not be honored and I paid for repairs. I changed the double-landing and still have F52 errors with the repaired units.
Contacted SS for information about what the actual damages were to the units. 2 weeks later - still waiting.
Very poor customer service in my opinion.
If SS had just let the Tech 1 person handle this I would be giving a much different review. But after he told me his boss involved himself in my issue, then delays and excuses started. In my case, it seems they actually went out of their way to make the process as difficult and slow as possible.
I’m running 4 ea 304’s or 64kWh and have issues, so it’s probably not.Boy it’s hard to say. I know that 1, 280ah battery isn’t gonna be enough to run up to full capacity, but I still wouldn’t think that would cause your issues.
Huh? Should be nice charts showing solar input, load, battery current, output voltage, etc in SA.I do have Solar Assistant and WatchPower but I wouldn't know what to share. It's just a huge list of numbers.
Yea I've seen a bunch of those threads... Bunch of baloney. Imo, it's a problem because it brings issues to light way better than watch power can...Interesting side note. Don't tell SS you use Solar Assistant. After all the tests we did and the tech said he knew the problem and I had to send the unit in for repair, then they ignored my issue and started making dumb requests that had nothing to do with my issue. When they found out I had Solar Assistant and the techs near exact words were "oh I didn't know you had that, that's your problem right there. Solar Assistant does not work with our inverters. It messes with the operation of them".
They might come on here and insult him. Vendors have been known to do that around here when upset.I wouldn’t expect anything more out of SS.
I have two 6500s and have ran problem free for 8.8 months. They handle everything I have thrown at them. On another note, I did take the upgrade program for the 18kpv. I would say the 6500 handle surges better. The 18 k is an awesome unit. Only thing about the 18k i don't like its too dang quiet...lol Have to turn a light on in my power shed to see if its working. I will use the 6500s as a backup.
