Simplefied BMS that integrates with chargers/investers?
walter-
Is there a BMS that integrates with an inverter but is only checking SOC? And not checking the individual cells?
Reason; most of the BMSs -like 16S- don't support a dedicated list of inverters. But they work fine to monitor cells, do some balancing and protect the battery against over/under voltage/currents...
An approach could be to use such a standard BMS for the battery and a second BMS that only based on SOC instructs the charger what to do. The second BMS could then also handle multiple packs in parallel.
And with integrate with an inverter, I mean on the level/quality that Batrium does who list a clear list of supported inverters (something I don't find with the cheaper BMSs).
<snip>
This requirement disqualifies anything along those lines.
Note that there is progress on feeding JBD, DALY and other BMS to Victron and other inverters.
Something like a Victron BMV-702 or BMV-712 can open/close a relay based on SoC, voltage and temperature limits. This can be used to feed a signal to to an inverter or a control coil on a relay.
I am looking for integration with Inverters, not standalone stuff. So I keep looking ;-).
Somehow the Victron Lynx Shunt VE.Can seems to be an answer to this question. But that is then a lock-in into the Victron system.
Actually here is the solution to my question, with the Victron shunt, but without the Victro lock-in;
