Solar Edge means optimizer per panel.
To move the PV panels over to an AIO, you have to remove the optimizers and possibly rearrange string.
It appears SolarEdge has their own AIO solution, which presumably is compatible with their optimizers, but I have not researched into it at any depth:
And finally, SolarEdge may have a much higher failure rate than other brands. Not all models or installations do, but we've seen some reports. A reason to consider replacing with a hybrid/AIO.
The original SE 11kW inverter that was put in service in 2015 lasted only about 5 years. Got it replaced under warranty with a newer "Home Wave" 10kW unit, it's a much more compact unit that runs much cooler which bodes well with better reliability. The optimizers, apart from one which was DOA, were solid all these years.
