stealthbob
First off, this is not specifically about solar power, so I apologize. I just really like the vibes here and figured I could get the help I need.
I’m experiencing a sudden issue with my 12V 100Ah LiTime LiFePO4 battery. I use a charger set to 14.5V, typically charging at around 25A. This setup serves as a portable power bank for my camping trips. It has worked great for a year without any issues, but now a problem has arisen.
I suspect this may have happened because I attempted to charge it in cold conditions. The temperature was just above 0°C, but I assumed that would be safe, and I relied on the BMS to protect it (I’ve confirmed it has a low-temperature cut-off). Since then, when I charge at 14.5V, the battery reaches that voltage and holds it, indicating no current. Once I stop charging, the voltage quickly drops to around 13V within a couple of hours. Additionally, it seems like the BMS still has it locked out because when I try to charge again, the charger indicates 14.5V with no amps flowing. If I put a load on the battery for a while and then attempt to charge, it will take a charge, but only to end up with the same result.
Interestingly, if I charge at a lower voltage, around 14.2V, this issue does not occur. The battery reaches 14.2V and holds the charge normally. I assume this is due to the voltage not reaching the BMS cut out?
Could this simply be an imbalance? Is it possible I damaged a cell, and if so, is this irreversible? What’s the best way to balance a single battery? Most resources I’ve found focus on balancing multiple battery banks.
