John Frum
Tell me your problems
- Nov 30, 2019
- 15,224
What mess?please clean up the mess in your previous comments @John Frum.
Please be specific.
We already went around on this, you say that this means we don't stand behind the breaker but how could that be if it specifies sizing breakers only if not included with the product? this is a categorically oxymoronic way to read this"The included breaker is not a guarantee of battery protection. Size and install the correct over
current protection for conductors and battery if not included with the product." -- https://signaturesolar.com/content/documents/EG4/EG4-LL 48V-24V Manual-1.2.0.pdf
I disagree.we have never used AC-Only Breakers.
You are all over this forum telling people these are AC breakers and in some comments you say you would remove the breaker and replace it with whatever janky fuse you wanted to pontificate on. pls get that off the web. we don't want to be dealing with jacked-up server rack batteries in our tech support dept.What mess?
Please be specific.
well we got you the spec sheet, you can get the language teacherI disagree.
the BMS will always trip before the DC breaker in posted video we show how much time the breaker takesView attachment 139221
Also states that the current protection is supplied by BMS. I know you don't agree that the BMS should be trusted, but it's designed to work before the breaker. I don't see what the issue is. It has two methods of protection. They can claim that BMS is responsible. I don't see the safety issue.
I don't trust any FET based BMS to protect against a dead short as I've said repeatedly in this thread.Gosh this is going no where just like in the past arguments. The proof is there. Manual states current protection is provided by BMS. Looks fine to me.
What's the issue John
I think of it as choosing wisely where to spend money. People have budgets, often far smaller than they would like. And there's a whole list of reasons why someone might end up with a system that isn't fused sanely. Such as a rackmount battery rack where the batteries have questionably rated breakers, or running batteries to a Lynx several feet away from the batteries, etc.IMO that is a waste of a class t fuse.
It seems to me, this whole thread and many others like it is about people trying to save money.
IMO over-current protection is the last place to try and save money.
If you, or anyone, does test that. IMHO Welder's mask and protective clothing and trigger it from a distance, juuuuuust in case theres an arc flash.I honestly don't want to ? I am scared. I've had a lot of bad experiences with dead short tests in my past.
I have the equipment to do it right now. But yikes! Haha ??
I can confirm I have the same breakers on My V2s. I think the manual still says they are not OCP, but I'll double checkJust realized the new EG4 packs have DC rated circuit breakers. Anyone else here have the updated model and wish to share their breaker?
View attachment 139210View attachment 139211
As written the manual reads (at least the PDF version linked elsewhere in this thead) as unambiguously saying that OCP MUST be provided outside of the battery. Now, perhaps I'm dumb but thats how I understood it from months ago.We were trying to address the potential for combined wires to carry more than the rated amperage. better words could have been used but clearly, we are referring to things "not included with the product" which disqualifies interpreting this to mean the battery breaker is not DC-rated.
this thread is very misleading and frankly defamatory in the comments saying that Chint says the breaker is not for DC. please clean up the mess in your previous comments @John Frum. tech support is already busy and this will plug the lines with nutty breaker questions next week
What length bolts do you need? I may have some long enough left over from my earlier PowerIn modifications and I would be happy to send them to you. Probably some leftover nuts and flat washers as well. I only have 4 copper split washers though and I would want to hold on to those.I’m ordering longer bolts, but this should give you an idea what it will look like:
Thanks for the offer. I already ordered some. I’ll let you know the proper length after I get them and if they’re too long, I have a grinding wheel.What length bolts do you need? I may have some long enough left over from my earlier PowerIn modifications and I would be happy to send them to you. Probably some leftover nuts and flat washers as well. I only have 4 copper split washers though and I would want to hold on to those.
What about SOK batteries? Have they sent/told you anything about their breakers?Where does the manual state that? They told me it was DC rated over a year ago.
I just don't like to state opinions and wait till we get the data sheet.
Now we have it. I couldnt recommend the packs unless it was DC rated. We had a big issue with this when I got my first pack. I should have posted the data sheet here or in resource section.
I spent a bunch of time on the Victron community site and saw some very interesting info, some of which was from Victron reps. Basically; 1) the BMS protects the battery for OCP, faster than fuses or CBs, (matches what Will was saying) 2) Class-T's were on battery banks as close to the busbar as possible, 3) the CNN's inside the Lynx Shunt were acceptable in Victron wiring diagrams for system OCP. Then I went to a company's site that has hundreds of installs under their belt, looked at their wiring schematics and they go with 1) Class-T's were only on battery banks also, 2) they had no problem with MRBF's to protect the battery to busbar wiring...wait for it...because they also said that the battery BMS provides OCP for the battery itself.Thanks for the offer. I already ordered some. I’ll let you know the proper length after I get them and if they’re too long, I have a grinding wheel.![]()
I understand it might be an overkill, but there’s a few members here that are very insistent and have me paranoid.I spent a bunch of time on the Victron community site and saw some very interesting info, some of which was from Victron reps. Basically; 1) the BMS protects the battery for OCP, faster than fuses or CBs, (matches what Will was saying) 2) Class-T's were on battery banks as close to the busbar as possible, 3) the CNN's inside the Lynx Shunt were acceptable in Victron wiring diagrams for system OCP. Then I went to a company's site that has hundreds of installs under their belt, looked at their wiring schematics and they go with 1) Class-T's were only on battery banks also, 2) they had no problem with MRBF's to protect the battery to busbar wiring...wait for it...because they also said that the battery BMS provides OCP for the battery itself.
I do like your idea of the Class-T inside the PowerIn based on what these companies are talking about. It would be another line of defense protecting all non-shorted batteries in the bank from the shorted battery should its BMS fail. And it would protect the other system components from the shorted battery as well.
Are you going to be using the Lynx Shunt with a CNN fuse? Or a Class-T for the entire bank without a Lynx Shunt?
Yeah, that whole "very insistent" thing got to me a little as well...then tunnel vision kicked in.I understand it might be an overkill, but there’s a few members here that are very insistent and have me paranoid.And some don’t even want Batteries in their house.
So as I posted, two paralleled batteries (100Ah x 2) per class T fuse. And another class T fuse from the Power In bank to the inverters.
No shunt planned currently.
You and me both ?I understand it might be an overkill, but there’s a few members here that are very insistent and have me paranoid.![]()
Your modification of the Lynx Power-In also has me intrigued.But please keep me updated on the whole PowerIn / Class-T thing...it sounds really interesting.
https://ahtrimble.com/2023/01/12/victron-energy-lynx-distribution-system-lynx-powerin-part-2/You and me both ?
Be nice to see a separate post on how you went about it from beginning to end.
I have a lot on my plate, so solar is kinda on the back burner for now. But will post pictures when I’m finished.Yeah, that whole "very insistent" thing got to me a little as well...then tunnel vision kicked in.
I am not technically savvy enough to know one way or the other...so I went back to Victron for their take on it. They were pretty clear. Then I went to someone who has done hundreds of installs for their take. I figure that those guys have a universe more technical knowledge than me. And with all those installs...if something wasn't right with their methodology it would have shown up by now. And they both backed up Will's comment about the battery OCP provided by the BMS. Trifecta of sound practical knowledge
I really like that you are stepping outside the box and actually making something. I can appreciate a DIY guy who is hands on. And who knows...maybe you are really on to something! Think patents...and millions
I am really thinking MRBF's on the batteries. But for now I just have to get this upgrade finished...then take a week off from everything!
{edit} If you get a minute...Why no shunt? What are you going to do for monitoring?
