Here's my battery set up parallel and bottom balancing just to annoy everyone.
I'll post the serial setup later
I think I'm more annoyed with the green glow than anything else ?
Yea it messes up the picture. I thought about turning it off.I think I'm more annoyed with the green glow than anything else ?
Great set-up, I like the BMS app readout! What BMS are you using?Here's some pictures of my latest setup. This is an evolving work in progress.
I moved the BMS and shunt to the back so I could get all of the balance wires out of the way.
The + distribution bar has a 100A MRBF fuse. I'm still deciding what to do about Class T fuses.
I don't like the serrated flange nuts. Especially on the balance leads. Next time they come off will be the last time.
As you can see I covered more of my ratchet and socket.
View attachment 34451View attachment 34453
My whole setup
Starting balanced from the bottom
Thanks. I really haven't gone overboard on making everything perfect. But I like neat and efficient.Gorgeous! Looks like you’ve still got a lot of work to do too! Do you like the MPP? I’ve been leaning towards going that way.
It is the Heltec smart BMS with active balance.Great set-up, I like the BMS app readout! What BMS are you using?
I assume they settle from weight. I don't know what is in there but my guess is that it is similar consistency to an aluminum prism filled with clay. But it expands and contracts. It's solid as hell but you can move it around a little by restraining the thickness and going through a few discharge/charge cycles.So basically your cells at the top have around the same delta with after a bottom balance as mine do at the bottom after a top balance. Makes perfect sense to me.
I haven't taken any measurements but it's visually obvious to me my cells get fatter at the bottom too.
I've been thinking about how careful I have to be when moving busbars, tools and wires around and I realized the damn ring extends the connection of everything in that hand about 1". I hate when it takes me so long to think of these things.One tip I learned 40 years ago, take off jewelry on your hands. That wedding ring is an excellent conductor. High current will melt that right on your finger. Unfortunately my glasses are for distance, but safety goggles are a great idea.
I don't wear a ring but maybe the mechanics gloves without fingertips would be useful. gloves are somewhat cumbersome, so thin and flexible insulating gloves may still help to make assembly safer. I am definitely more careful after arc-ing a few cells (272Ah Lishen) and it ruining 2 studs.I've been thinking about how careful I have to be when moving busbars, tools and wires around and I realized the damn ring extends the connection of everything in that hand about 1". I hate when it takes me so long to think of these things.
i totally understand. I can’t remember what it’s called but you can buy it at auto stores and it comes as a almost liquid rubber and it’s meant to recoat tool handles. You just dip the handle in it, dry then repeat for thicker coating. I thought about using that to cover my bus bars and studs becaus it would be easy to just peel off down the road too. 3D printed covers would look much better though. Printers are a little to expensive for me to buy just for that th
Cool, I'll cover my ring. lolHere it is on Amazon but available in many big box stores:
Amazon.com: Performix 12219 Plasti Dip Clear - 22 oz. Dip Can: Automotive
Buy Performix 12219 Plasti Dip Clear - 22 oz. Dip Can: Polishing & Rubbing Compounds - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Thanks
