ocnboating
I have a 2019 5th wheel RV that is prewired for 30 AMP solar system. I have no experience in solar wiring of the RV. I see cables marked for Solar in my battery compartment and wires to where the solar controller is being recommended to be installed next to the main DC and AC circuit panel. My main feed to the RV is 50 amps. I have used 30amp connection many times when 50 amp wasn't available. I have a gas electric refrigerator, gas electric water heater.
Knowing the above how many watts of solar panels do I need, size of inverter and I would like and automatic transfer switch. My understand with a transfer switch I can run on solar during the day and switch to battery and than to shore power once that batteries can't support the load. Current battery configuration is (2) six volt acid batteries wired in series 240 amp hr. The plan is to go with (4) 6 volt batteries.
I have looked at the RICH panels. They have a 400Watt package excluding the transfer switch. The transfer switch I was thinking on using was the Rohs ATS.
Any help and recommendation I can get will be greatly appreciated.
New to RV Solar
Ron
New to RV Solar
Ron
