AlaskanNoob
- Feb 20, 2021
- 906
I'm trying to figure out how much PV (LG 440N2T-E6 panels) I can plug into a Victron 450/200 SCC.
From what I understand, the SCC has 4 trackers where PV can be plugged in. Each tracker is limited to accepting 450volt and 20 amps.
I know I can wire up 7 panels in series for a total voltage of 365V (using my temp correction of 1.23). I say I know that because the LG specs sheet lists VOC for STC, BIFI100, and BIFI200 as 48.9 so I'm using that as the VOC even though I have no idea what BIFI100 or BIFI200 are.
But it appears the ISC is 11.18 for STC, 11.94 for BIFI100, and 12.7 for BIFI200. Whichever of those numbers I use would mean I could not parallel any string of 7 panels because it would result in more than 20 amps.
So unless I'm doing this completely wrong (which is very likely) the 450/200 SCC could only accept 7 of these panels per tracker for a total of only 28 panels.
Can somebody educate me? I'm confused about BIFI100 and BIFI200 and I'm not sure if these specs are including the extra power production that comes from the panel taking in sun from both sides.
