200w @ 12V is only going to yield 17A at most, a brief cloud lens event is not likely to push anywhere past 30A, so your fuse is safe. And with a 30A fuse 10 ga wire is the smallest you can go.
( edit - sorry - didn't see the "between panels and controller" . I agree with time2roll, no fuse needed with only 2 panels on the PV side.
However - you then need a switch or circuit breaker there, because MPPT controllers need to boot up from battery power first, and then apply the PV power to them. mix up that start up sequence and you have a good chance of frying the controller [ maybe not with only 200w of panels ] )
Many fuse holders are not rated to make/break the circuit, and they rely on the fuse cartridge , not the user unplugging the fuse, so be aware of that before you buy.
