My last install used a Victron Multiplus which had a single AC input, so I had no choice but to use the existing Automatic Transfer Switch for shore power and the on-board generator. My new install uses a Victron Quattro which has two AC inputs with an internal Automatic Transfer Switch.
Is there any advantage to bypassing the OEM Automatic Transfer Switch?
It seems to me that using the Automatic Transfer Switch saves me about 10' of 10/3 cable since I would need only one run to the inverter.
One reason to wire shore power and the generator both directly to the Quattro on AC Input 1 and AC Input 2 is that I can set the Max Input Amps for each source and not ever have to change it for the generator.
