carlsonultimate
- Apr 17, 2022
- 13
Hi,
I recently replaced my old lead acid batteries with new signature solar eg4ll batteries.
System specs
Two Sunny boys AC coupled with Two Sunny islands
10,000W PV running two the sunny boys
1 outback flexmax80 with 3000W PV
12 (48V) signature Solar EG4ll LFP Batteries (60KW)(1200AHr)
Propane backup geni
I went through the new battery set up on the SI and set to VLRA as suggested by tech support sense the BMS on the EG4's is not compatible with the the SI's.
set as
48 V
VLRA
1200AHr
System started up fine but the SOC on the SI has been significantly lower than what the EG4 read. Example; the SI read 1% and the EG4's read 78% at 53.3V. So this is my first problem I am not able to use the whole capacity of the batteries. The second problem is during charging the EG4's go into Over voltage protection around 54V. The specs for the BMS say that OV protection occurs at 60V so maybe I just haven't been there to observe it. I've lowered all of the charging values to 2.3V. Once the EG4's go into OV the SI will start to give a F201 Malfunction VBATMAX, this happens 3 times with the system turning off for about 30 seconds and coming back on until I get a F710 Failure autostrcnt which puts it in standby.
Can anyone recommend different settings? Any help would be greatly appreciated, I've talked to SMA tech support but there not much help, they just tell me that the EG4's are not a supported battery...
System specs
Propane backup geni
set as
48 V
VLRA
1200AHr
