svsagres wrote:
I don't understand the first sentence, because I don't know what "...have the contactors (relays) wired to the battery" means.
I don't believe you read the notes at the bottom of the diagram. I do want them "cascaded" because the primary BMS coil relay (normally open) when the control power is off, fails to "open" and disconnects and isolates the entire LFP battery (both the charge bus and the load bus) as required by ABYC.
The second Emergency coil relay is normally closed, and it fails "closed" when power is off, thus connecting the DC Panel to the FLA battery and allows essential equipment to be powered.
I've decided to use
Blueseas Solenoid L-Series - 250A 12/24V #9012 $240 for the primary relay coil. The other coil could be a less expensive 50A coil, but I might just use a manual switch. This will use 0.13a x 24 hours = 3.12amps/day which currently is about 20%-25% of the daily solar output.
Is it possible to power the BMS and Wakespeed WS500 from the FLA instead of the LFP so that the monitoring functions do not shut down when the primary coil disconnects the LFP? Of course the sensor wires would be connected to the LFP. This would help us determine what the failure mode was.
Additionally, I need to show an "advanced alarm" circuit to meet ABYC.
Please keep in mind the original goal here was "Small boat BMS/LFP with backup" and in the first post I stated that the DC Loads should be powered by the FLA, because we should assume that the LFP are somewhat fragile and will fail sometime. I have changed my attitude about that somewhat, by having the DC Loads powered by LFP and switched to FLA on failure.
