small cabin offgrid 48v system help
mmdb
I have small remote cabin and I'd like to install a solar system . im there mostly on weekends(not overnight ),and sometimes during week to do gardening work, I'd like lights, refrigerator, water pump, TV, stereo (and maybe small water heater to wash dishes) when i go there with friends and familly .Is this good system for me
solar inverter charger this one
5000W Pure Sine Wave Inverter 500Vdc PV Input 230Vac 48V 80A MPPT Solar Charger
8 panels in series mono 450Wp 72 cells
4 or 8 batteries 260ah each
Combined refrigerator and freezer cca (180kwh annually) and small water pump main consumors and occasionally water heater
  • Screenshot_2020-11-07 HRK3747 74 15% OFF EASUN POWER Solar Inverter With Wifi 5000W Pure Sine ...png
  • Screenshot_2020-11-07 Shop GWL Solar panel GWL Sunny Mono 450Wp 72 cells, PERC (ESM-450).png
snoobler
Solar Honey Badger
HBR, AZ
Are you based in the United states?
Have you conducted an energy audit to determine your actual needs? If not, link #1 in my sig.
Have you determined the available solar for your location, panel orientation and tilt? If not, link #5 in my sig.
Failure to conduct the above steps results in a system that won't meet your needs or costs to much.
mmdb
Hello .Thx snoobler ..No im in Europe Croatia .
After lot of reading i decided to go with this ..
batteries -280ah eve cells ,already buy 20 cells ,and i will have 4 spare (maybe do 1 12v battery )
inverter charger will go with LFI 6kw must pv3500 pro
solar panels will go with Yangtze 500 w each ( minimum order 20pc but i will use only 8)
