timeforagorism
- Oct 4, 2020
- 8
This is my first system. As you can probably tell it was modeled after Will's videos and links. It was easy to recognize Will as a ‘trusted source’. I definitely don’t mind contributing to that 50K a month affiliate linkage ?
The final goal of whatever system I come up with will be to handle a 360 sq ft cabin. The cabin will be super insulated with a solid air barrier. Matt Risinger, and David Poz’s content has given me many things to consider.
Loads:
Current load:
The fortune cells were really nice to work with as someone being brand new to DIY batteries. Especially during the top balance process as the lugs are so beefy. The Overkill solar BMS are great because I can monitor each pack during cycles. Although Will’s latest video has me wanting to buy the Victron monitor that is 130 now, the other 200 dollar one was hard to justify.
Loads I am running on the prototype daily:
Things I still need to do:
Loads:
- Power tools
- Maybe a base board electric heater for evenings. With the small space, super-efficient building techniques, and passive day heating this may do.
- Maybe a pellet stove. These seem to pull 70watts continuous and 400w for the ignitor.
- Lights
- On demand water pump
- Freezer
- Converted stand up freezer to fridge
- CPAP
- All the other things I haven’t calculated load for yet.
Current load:
- Stand up Freezer – 400 watt hours daily
- Converted Stand up freezer to fridge – 400 watt hours daily
- 8W Led lights
- Ground the array
- Ground the inverter and do more research on this. I need to learn more about grounding is the moral of that story.
- Figure out how to build compression boxes for the Lishen 272AH cells I just bought.
- Double or triple this array at the cabin
- Find a suitable inverter, charger, or some combination of those.
- Stalk these forums more
