I have a small cabin that gets used a few weeks a year. Today it has a single 100w panel and an old charge controller and a 12v LA battery that runs a few LED lights and a 12v water pump. Dad wants a bit more power so he can charge his laptop, run a small coffee maker in the mornings, and potentially run Starlink internet.
My current thought is to use an all-in-one (SPF 3000TL LVM-ES), used panels (santan 250w), and renology 48v batteries (RBT50LFP48S-US).
I am planning to wire up 6 panels in series (~225V) to get the voltage up to what is needed for the AIO (needs >150V to start per docs). The panels are cheap so we might do two groups of 6 for 3000w (if I am going to pay for shipping might as well load up the pallet). The panels are going to be on a ground mount behind the structure and have clear space around them so they can face due South. I wasn't planning on doing much in the way of batteries, potentially just one to buffer the AIO so it runs stable during the day when there is sun. The cabin has wiring and a small breaker box that I was going to wire into from the AIO to provide power to the lights and outlets and then do a 48V to 12V DC-DC converter for the water pump.
I am looking for a basic sanity check on the plan, will it work, and then secondarily is there anything that would significantly improve this for roughly the same cost/effort/complexity? I realize that 3kw in panels isn't matched well to 50-100ah of batteries but I am not looking to run the system or need power for long if there isn't sun.
Thanks in advance.
Thanks in advance.
