Any particular reason for diesel? That’s kinda the sweet spot for portable gasoline/propane/NG generators…Hello,
Any recommendations for a 2000-5000W portable diesel generator?
I have dyed diesel storage for the tractor.Any particular reason for diesel? That’s kinda the sweet spot for portable gasoline/propane/NG generators…
Not that diesel isn’t better in some ways, just curious what your criteria are
My parents have a dead Onan (propane) sitting in their yard that lasted 4-5 years. It could probably be revived, but after two main circuit boards and a Cummins tech scratching his ass on a connected laptop for three days trying to figure out generators (no clue), they abandoned it.This what you want:
Cummins Onan QD 5000 Commercial Mobile Diesel Generator - 5.0HDKBC-2861, 5 kW Prime, Single-Phase, 120/240 Volt, Liquid-cooled
Cummins Onan QD 5000 Commercial Mobile Diesel Generator - 5.0HDKBC-2861, 5 kW Prime, Single-Phase, 120/240 Volt, Liquid-cooled Automatic glow plug eliminates preheat time uncertainty. Efficient and convenient operation monitoring and control. Conveniwww.absolutegenerators.com
No, it's not cheap, but if you change the oil, it will last longer than you.
What about a PTO generator?I have dyed diesel storage for the tractor.
Yes, I had an Onan 7000 (diesel) in a motorhome at one time and it worked without issue for years.This what you want:
I thought about it and looked around but, decided a dedicated engine/generator would be a better solution, for me.What about a PTO generator?
Photo taken just now through a screen and dirty window.Diesel and propane generators predate laptops.
An old rebuilt one could be better. Until the last of the mechanics die off?
What is used in refrigerated sea going containers?
The Kubota Lowboys are 3600 RPM.Light tower generators are 1800 rpm diesels in the 4 to 8 kw range. Kubota, Kohler and Mitsubishi are common engine manufacturers typically 3 cyl around 1 liter.
I believe the kubota low boy and some semi apu gensets use the Kubota z482 which is roughly.5 liter 2 cyl, which is why they run that fast. there are small 1 cyl air cooled diesels by yanmar and others. Everything is a trade off between size weight service life, efficiency etc
Such are electric, not propane or diesel.What is used in refrigerated sea going containers?
Lot easier to run power cords then diesel lines. Plus safer and more reliable.Yeah but ...
What a maze of extension cords it takes to provide power to all the electric refrigerated containers?
