No such thing as a cheap MPPT SCC, and that's what you need for an ideal solution.
Alternate:
Amazon.com: DC Buck Converter, DROK DC to DC Step Down Power Supply Module 10V-65V to 0-60V 0-12A Adjustable Voltage Regulator Transformer Board with LED Display for Volt Reducer: Home Audio & Theater
www.amazon.com
2X 12V panels in series at the input (meets the 10-65V input limit)
output set to 21V (output 0-60V)
output set to 2-3A
The downside here is there's no means for cut-off. With the charge controller, once 21V is hit, it terminates charge and floats the battery. Your current will just drop to zero. Leaving the battery like this for an extended period would damage it. Since his float was 20.5? You could try setting it to that. Your charge will take a little longer, and you might only get to 90%, but there are prices to pay for compromise.
Since the little display can show current, that would be a good "full" indicator for you.
DROK Step Down Voltage Regulator
Product Parameters:
·Input Voltage Range: 10V-65V
·Adjustable Output Voltage Range: 0-60V
·Adjustable Output Current Range: 0-12A
·Output Power: 0-720W
·Output Voltage Setting Resolution: 10mV
·Output Current Setting Resolution: 10mA
·Typical Efficiency: 94% (input 54V, output 30V, current 5A)
·Voltage Display Error: ±1%+20mV
·Current Display Error: ±1%+20mA
·Response Time: <50ms
Product Features:
·The DROK DC-DC numerical control buck voltage converter is a programmable buck module with all-digital LED display which can display real-time voltage and current.
·Compared to the similar product, you will find that this buck module has a compact size and it works efficiently and stable.
·We applied advanced microprocessor control for this buck module. Voltage and current can be adjusted accurately by pressing the button, you can adjust it to output constant voltage and current.
·Package Includes: DROK DC-DC Buck Converter Module ×1
