OhYou_
I just picked up ~10kw of panels (36x315w) and I need to start mounting them up soonish.
My goal is 6s6p, I have 2ga THHN 600v rated copper to run between the controller and the array (6-8M run)
That's about as far as I've got.
Charge controller is 128V 180A rated and I forgot how much VoC but more than enough for 6s at 42v each
All the power side equipment is in place and running off of 1.2kw of panels I mounted earlier to test before I got the 36.
NEC rules dont apply here so I dont need AFCI, dont need rapid shutdown, and knowing this risk, I instead want to mitigate it by basically making sure everything is done well so that there instead isnt a failure. I might implement GFCI, though it will be diy.
My plan is to get the wire out to some kind of box where I break out into 6x inputs, one for each panel string.
Does anyone have recommendations for basically everything? I'm probably underthinking it.
Atm I'm thinking I just run EMT out to a metal enclosure under the roof, pull the 2ga through it, hook it up to some splitters, run some pv wire out under the roof and pop it through to connect to the panels using some kind of roof jacks. Should the 6x PV wire also be in conduit?
Should I worry about conduit on the roof itself? it is a flat metal roof with wood below the metal roughly every 4ft, I can just screw brackets into those to mount the panels or something or if I really need strength, there is W beam directly under the wood, I can bolt it down instead.
No idea on panel mounts, the 4 are up there with 2x4 and a cheap set of panel mount brackets that wouldnt be very cheap at 36x
